The Prediction Profiler can be accessed from the Graph menu or the red triangle menus of certain platforms.
• The Prediction Profiler can be accessed directly from the Graph menu. When you access the Prediction Profiler in this way, the Prediction Profiler launch window appears. See Profiler Launch Windows.
• The Prediction Profiler can be accessed as a red triangle menu option in many modeling platforms. See Where to Find JMP Profilers for more information about the availability of the Prediction Profiler in different platforms.
• The Prediction Profiler can be accessed from the Model Comparisons platform. Select Profiler from the Model Comparisons red triangle menu.
• The Prediction Profiler can be accessed from the Formula Depot platform. Select Profiler from the Formula Depot red triangle menu.
