Use the Stem and Leaf option in the Distribution platform to show an interactive text plot of the data. Each line of the plot has a Stem value that is the leading digit of a range of column values. The Leaf values are made from the next-in-line digits of the values. You can see the data point by joining the stem and leaf. In some cases, the numbers on the stem and leaf plot are rounded versions of the actual data in the table. The stem-and-leaf plot actively responds to clicking and the brush tool.
Note: The stem-and-leaf plot converts fractional frequencies to the smallest integer greater than or equal to the specified frequency.
