In JMP, data can be of different types. JMP refers to this as the modeling type of the data. Table 5.1 describes the various modeling types in JMP.
Modeling Type and Description |
Examples |
Specific Example |
Continuous Numeric data only. Used in operations like sums and means. |
Height Temperature Time |
The time to complete a test might be 2 hours, or 2.13 hours. |
Ordinal Numeric or character data. Values belong to ordered categories. |
Month (1,2,...,12) Letter grade (A, B,...F) Size (small, medium, large) |
The month of the year can be 2 (February) or 3 (March), but not 2.13. February comes before March. |
Nominal Numeric or character data. Values belong to categories, but the order is not important. |
Gender (M or F) Color Test result (pass or fail) |
The gender can be M or F, with no order. Gender categories can also be represented by a number (M=1 and F=2). |
Multiple Response Character data only. Distinct entries in a single cell that are separated by commas. |
When you brush your teeth College degrees Sports you play |
There are several times a day that you could brush your teeth. First thing in the morning, after breakfast, after meals, before bed, or any combination of the above. |
Unstructured Text Character data only. Usually all unique values that must be analyzed using Text Explorer. |
Product reviews Song lyrics Free response field in survey |
Most product reviews would be unique and Text Explorer is used to determine any underlying similarities. |
Vector Expression data only. Values in a cell are column or row vectors. |
Prediction formulas |
None Any data type. Used in scenarios where a column is not well represented by the other modeling types. |
Pictures ID Values |
A picture column in a data table would not be used to modeling, but could be used as a marker on a graph for example. |
