Table 15.2 shows which JMP data types can be exchanged with Python using the Python Get() function. Getting lists from Python recursively examines each element of the list and gets each base Python data type. Nested lists are supported.
Python Data Type |
JMP Data Type |
numpy.ndarray |
Numeric Matrix |
jmp.DataTable.Column |
Column |
jmp.DataTable |
Data Table |
Pandas.DataFrame |
Data Table |
Dictionary |
Associative Array |
Integer |
Integer |
List |
List of converted Python data types |
Matrix |
Numeric Matrix |
Set |
List |
Unicode String |
String |
Names Default To Here( 1 );
x1 = {1, 2, 3};
Python Send( x1 );
x2 = Python Get( x1 );
Show( x1, x2 );
