The Evaluate Design red triangle menu contains the following options:
Advanced Options
Split Plot Variance Ratio
Specifies the ratio of the variance of the random whole plot and the subplot variance (if present) to the error variance. Before setting this value, you must define a hard-to-change factor for your split-plot design, or hard and very-hard-to-change factors for your split-split-plot design. Then you can enter one or two positive numbers for the variance ratios, depending on whether you have specified a split-plot or a split-split-plot design.
Save Script to Script Window
Enables you to save a script that reproduces the report to a script window.
Save Script to Data Table
Enables you to save a script that reproduces the report to the data table.
