Use the Evaluate Design platform to evaluate the strengths and limitations of a design that is contained in a design table. Gain insight on aliasing in your design with the alias matrix that shows the bias structure for model effects. Determine the ability of your design to detect effects of a size of interest with power analysis. Investigate estimated prediction variance of your design with the prediction variance profilers and surface plots.
Some sections of the Evaluate Design platform are also available in DOE platforms and the Compare Designs platform.
Figure 16.1 Fraction of Design Space PlotĀ
