The Type 1 Gauge Study red triangle menu contains the following options:
Save
Shows a submenu of the following options:
Save Type 1 Gauge Metadata as Column Properties
Saves the Type 1 Gauge metadata as MSA column properties in the data table.
Save Type 1 Gauge Metadata to Table
Saves a new data table that contains the Type 1 Gauge metadata for each column.
See “Local Data Filters in JMP Reports”, “Redo Menus in JMP Reports”, “Group Platform”, and “Save Script Menus in JMP Reports” in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
