One way to create data partitions is to use the Validation Column role. The Validation Column role uses the column’s values to divide the data into parts. The column is assigned using the Validation role in the platform’s launch window. For information about how to create a validation column, see “Make Validation Column”.
The Validation Column role is available only in JMP Pro. For JMP, see Excluded Rows as Validation Holdback.
Caution: The use of a validation column is platform specific. Different platforms use the levels of the validation column differently. See notes in Table A.1.
Table A.1 Validation Column by Platform
Platform |
Train & Evaluate |
Train & Tune |
Train, Tune, & Evaluate |
Notes |
Fit Model |
Fit Least Squares |
Yes |
No |
No |
If there are more than three levels, the validation column is ignored. |
Stepwise Regression |
No |
Yes |
Yes |
If there are more than three levels, K-Fold Cross-Validation is used. |
Logistic Regression |
Yes |
No |
No |
Generalized Regression |
No |
Yes |
Yes |
Partial Least Squares |
No |
Yes |
Yes |
Predictive Models |
Neural |
No |
Yes |
Yes |
Partition |
No |
Yes |
Yes |
If there are more than three levels, the platform uses only rows with the three smallest values. |
Bootstrap Forest |
No |
Yes |
Yes |
Boosted Tree |
No |
Yes |
Yes |
K Nearest Neighbors |
No |
Yes |
Yes |
Naive Bayes |
No |
Yes |
Yes |
Support Vector Machines |
Yes |
Yes |
Yes |
Model Screening |
Yes |
Yes |
Yes |
Specialized Models |
Functional Data Explorer |
Yes |
No |
No |
Must be created as a Grouped Random validation column. If there are more than two levels, the smallest value defines the training set and all other values define the validation set. |
Multivariate Models |
Discriminant |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Uplift |
No |
Yes |
Yes |
