Using JMP > Save and Share Your Data > Work with Projects > Write a Project On Open Script
Publication date: 02/06/2025
In the Project On Open Script box, you can add a JSL script that will run each time this specific project is opened. For example, you can create a script that creates or modifies reports, prompts the user for information, or writes usage information to the log window.
1. Select Project > Project Settings.
2. Paste the JSL script and click OK.
Tips:
See “Run Startup Scripts to Control Workspaces” in the Scripting Guide, which explains how to create a start-up script when any project is opened (instead of a specific project).
To use an existing project as a template for new projects, specify the existing project as a new project template under File > Preferences > Projects.
