JSL Syntax Reference > JSL Functions, Operators, and Messages > Character Functions
Publication date: 06/27/2024
Character Functions
Most character functions take character arguments and quoted return character strings, although some take numeric arguments or return numeric data. Arguments that are literal character strings must be enclosed in quotation marks.
Work with Character Functions in the Scripting Guide provides more information about some of the functions.
BLOB To Char(blob, <Encoding="enc">)
Description
Reinterpret binary data as a quoted Unicode string.
Returns
A quoted string.
Required Argument
blob
A binary large object.
Optional Argument
Encoding
A quoted string that specifies an encoding. The default encoding for the character string is "utf-8". "utf-16le", "utf-16be", "us-ascii", "iso-8859-1", "ascii~hex", "shift-jis", and "euc-jp" are also supported.
Notes
The optional argument "ascii~hex" is intended to make conversions of blobs containing normal ASCII data simpler when the data might contain CR, LF, or TAB characters (for example) and those characters do not need any special attention.
See Also
Hexadecimal and BLOB Functions in the Scripting Guide
BLOB To Matrix(blob, type, bytes, endian, <nCols>)
Description
Creates a matrix by converting each byte in the blob to numbers.
Returns
A matrix that represents the blob.
Required Arguments
blob
A blob or reference to a blob.
type
A quoted string that contains the named type of number. The options are "int", "uint", or "float".
bytes
Byte size of the data in the blob. Options are 1, 2, 4, or 8.
endian
The quoted endian-ness of your system: "Big" (the first byte is most significant), "Little" (the first byte is the least significant), or "Native" (the machine’s native format).
Optional Argument
<nCols>
The number of columns in the matrix. The default value is 1.
See Also
Char(x, <width>, <decimal>, < <<Use Locale(Boolean)>)
Description
Converts an expression or numeric value into a quoted character string.
Returns
A quoted string.
Required Argument
x
an expression or a numeric value. An expression must be quoted with Expr(). Otherwise, its evaluated value is converted to a quoted string.
Optional Arguments
width
A number that sets the maximum number of characters in the quoted string.
decimal
A number that sets the maximum number of places after the decimal that is included in the quoted string.
Use Locale(Boolean)
Preserves locale-specific numeric formatting.
Example
Char( Pi(), 10, 4)
"3.1416"
Char( Pi(), 3, 4)
"3.1"
Notes
The width argument overrides the decimal argument.
See Also
Numbers and Strings in the Scripting Guide
Char To BLOB(string, <encoding="enc">)
Description
Converts a quoted string of characters into a binary (blob).
Returns
A binary object.
Required Argument
string
A quoted string or a reference to a string.
Optional Argument
encoding
A quoted string that specifies an encoding. The default encoding for the blob is "utf-8". "utf-16le", "utf-16be", "us-ascii", "iso-8859-1", "ascii~hex", "shift-jis", and "euc-jp" are also supported.
Notes
Converting BLOBs into printable format escapes \ (in addition to ~ " ! and characters outside of the printable ASCII range) into hex notation (~5C for the backslash character).
x = Char To BLOB( "abc\def\!n" );
y = BLOB To Char( x, encoding = "ASCII~HEX" );
If(
	y == "abc~5Cdef~0A", "JMP 12.2 and later behavior",
	y == "abc\def~0A", "Pre-JMP 12.2 behavior"
"JMP 12.2 and later behavior" // output
See Also
Char To Hex(value, <integer|encoding="enc">)
Hex(value, <integer|encoding="enc"|Base(number)|Pad To(number)>)
Description
Returns the hexadecimal (or other base number system) text corresponding to the given value and encoding, which can be a number a quoted string or a blob. If the value is a number, IEEE 754 64-bit encoding is used unless one of the optional arguments, integer, or Base, is provided.
Required Argument
value
Any number, quoted string, or blob.
Optional Arguments
integer
A quoted switch that causes the value to be interpreted as an integer.
encoding
A quoted string that specifies an encoding. The default encoding is "utf-8". "utf-16le", "utf-16be", "us-ascii", "iso-8859-1", "ascii~hex", "shift-jis", and "euc-jp" are also supported.
Base(number)
An integer value between 2 and 36 inclusive. If base is specified, the function returns the text corresponding to the specified number in that base number system instead of hexadecimal.
Pad To(number)
A value to specify the padded width of the hex output.
See Also
Collapse Whitespace(text)
Description
Trims leading and trailing whitespace and replaces interior whitespace with a single space. That is, if more than one white space character is present, the Collapse Whitespace function replaces the two spaces with one space.
Returns
A quoted string.
Required Argument
text
A quoted string.
Concat(a, b)
Concat(A, B)
a||b
A||B
Description
For quoted strings: Appends the string b to the string a. Neither argument is changed.
For lists: Appends the list b to the list a. Neither argument is changed.
For matrices: Horizontal concatenation of two matrices, A and B.
Returns
For quoted strings: A quoted string composed of the string a directly followed by the string b.
For lists: A list composed of the list a directly followed by the list b.
For matrices: A matrix.
Arguments
Two or more quoted strings, quoted string variables, lists, or matrices.
Example
a = "Hello"; b = " "; c = "World"; a || b || c;
"Hello World"
d = {"apples", "bananas"}; e = {"peaches", "pears"}; Concat( d, e );
{"apples", "bananas", "peaches", "pears"}
A = [1 2 3]; B = [4 5 6]; Concat( A, B );
[1 2 3 4 5 6]
Notes
More than two arguments can be strung together. Each additional quoted string is appended to the end, in left to right order. Each additional matrix is appended in left to right order.
See Also
Concat Items
See Concat Items({string1, string2, ...}, <delimiter>}).
Concat To(a, b)
Concat To(a, b)
a||=b
A||=B
Description
For quoted strings: Appends the string b to the string a and places the new concatenated string into a.
For matrices: Appends the matrix b to the matrix a and places the new concatenated matrix into a.
For lists: Appends the list b to the list and places the new concatenated list into a.
Returns
For quoted strings: A string composed of the string a directly followed by the string b.
Arguments
Two or more quoted strings, quoted string variables, matrices, or lists. The first variable must be a variable whose value can be changed.
Notes
More than two arguments can be strung together. Each additional quoted string, matrix, or list is appended to the end, in left to right order.
Example
a = "Hello"; b = " "; c = "World"; Concat To( a, b, c ); Show( a );
a = "Hello World"
A = [1 2 3]; B = [4 5 6]; Concat To( A, B ); Show( A );
A = [1 2 3 4 5 6];
d = {"apples", "bananas"}; e = {"peaches", "pears"}; Concat to(d,e); Show( d );
d = {"apples", "bananas", "peaches", "pears"};
See Also
Concatenate Lists in the Scripting Guide
Contains(whole, part, <start>)
Description
Determines whether part is contained within whole.
Returns
If part is found: For lists, quoted strings, and namespaces, the numeric position where the first occurrence of part is located. For associative arrays, 1.
If part is not found, 0 is returned in all cases.
Required Arguments
whole
A quoted string, list, namespace, or associative array.
part
For a quoted string or namespace, a string that can be part of the string whole. For a list, an item that can be an item in the list whole. For an associative array, a key that can be one of the keys in the map whole.
Optional Argument
start
A numeric argument that specifies a starting point within whole. If start is negative, contains searches whole for part backwards, beginning with the position specified by the length of wholestart. Note that start is meaningless for associative arrays and is ignored.
Example
nameList={"Katie", "Louise", "Jane", "Jaclyn"};
r = Contains(nameList, "Katie");
The example returns a 1 because “Katie” is the first item in the list.
See Also
Locate Items in a List in the Scripting Guide
Find Keys or Values in an Associative Array in the Scripting Guide
Contains Item(x, <item | {list} | pattern>, <delimiter>)
Description
Identifies multiple responses by searching for the specified item, list, pattern, or delimiter. The function can be used on columns with the Multiple Response modeling type or column property.
Returns
Returns a Boolean that indicates whether the word (item), one of a list of words (list), or pattern (pattern) matches one of the words in the text represented by x. Words are delimited by the characters in the optional quoted delimiter (delimiter) string. A comma is the default delimiter. Blanks are trimmed from the ends of each extracted word from the input text string (x).
Example
The following example searches for “pots” followed by a comma and then outputs the result.
x = "Franklin Garden Supply is a leading online store featuring garden decor, statues, pots, shovels, benches, and much more.";
b = Contains Item( x, "pots", "," );
If( b,
	Write( "The specified items were found."  ), Write( "No match." )
Ends With(string, substring)
Description
Determines whether the quoted substring appears at the end of string.
Returns
1 if quoted string ends with a quoted substring, otherwise 0.
Required Arguments
string
A quoted string or a quoted string variable. Can also be a list.
substring
Equivalent Expression
Right(string, Length(substring)) == substring
See Char To Hex(value, <integer|encoding="enc">).
Hex To BLOB(string)
Description
Converts the quoted hexadecimal string (including whitespace characters) to a blob (binary large object).
Example
Hex To BLOB( "4A4D50" );
Char To BLOB("JMP", "ascii~hex")
See Also
Hex To Char(string, <encoding>)
Description
Converts the quoted hexadecimal string to its character equivalent.
Example
Hex To Char( "30" ) results in “0”.
Notes
The default quoted encoding for character string is "utf-8". "utf-16le", "utf-16be", "us-ascii", "iso-8859-1", "ascii~hex", "shift-jis", and "euc-jp" are also supported.
See Also
Hex To Number(string, <Base(number)>)
Description
Returns the number corresponding to the hexadecimal (or other base number system) text.
Required Argument
string
A quoted hexadecimal string.
Optional Argument
Base(number)
An integer between 2 and 36 inclusive. If base is specified, the text is treated as a quoted string representing the number in that base.
Example
Hex To Number( "80" );
128
Notes
16-digit hexadecimal numbers are converted as IEEE 754 64-bit floating point numbers. Otherwise, the input is treated as a hexadecimal integer.
Whitespace between bytes (or pairs of digits) and in the middle of bytes is permitted (for example, FF 1919 and F F1919).
Insert
See Insert(source, item, <position>).
Insert Into
See Insert Into(source, item, <position>).
Item(n|[first last], string, <delimiter>, <Unmatched(result string)>, <Include Boundary Delimiters(Boolean)>)
Description
Returns the nth item or the span from the first to last item of the quoted string according to the quoted string delimiters given. If you include a third argument, any and all characters in that argument are taken to be delimiters.
Required Arguments
n
The position of the word being extracted.
[first last]
A matrix that defines the beginning and end word range to return.
string
The quoted string that is evaluated.
Optional Arguments
delimiter
The character used as a boundary. If delimiter is absent, an ASCII space is used. If delimiter is the quoted empty string, each character is treated as a separate word.
The quoted string to print if no match is found.
Determines how delimiters on the front and back of string are treated. The default value is false, which means that the delimiters on these boundaries are ignored. If the value is true, delimiters on these boundaries produce an empty element (similar to consecutive delimiters within a string).
Example
Consecutive delimiters are treated as though they have a word between them. In this example, the delimiters are a comma and a space.
Item( 4,"the  quick, brown fox", ", " ); // quick is preceded by two spaces
The expression is processed as follows:
the<delim[space]><word2><delim[space]>quick<delim[comma]><word 4><delim[space]>brown<delim[space]>fox
Because word4 is empty, this expression returns a quoted empty string.
Item() is the same as Word() except that Item() treats each delimiter character as a separate delimiter, and Word() treats several adjacent delimiters as a single delimiter.
Word( 4,"the  quick, brown fox", ", " ); // quick is preceded by two spaces
This expression is processed as follows:
the<delim[2 spaces]>quick<delim[comma + space]>brown<delim[space]>fox
It returns "fox".
Left(string, n, <filler>)
Left({list}, n, <filler>)
Description
Returns a truncated or padded version of the original quoted string or list. The result contains the left n characters or list items, padded with any filler on the right if the length of string is less than n.
Length(string)
Description
Returns the length of the given quoted string (in characters), list (in items), associative array (in number of keys), BLOB (in bytes), matrix (in elements), namespace (in number of functions and variables), or class (in number of methods, functions, and variables).
See Also
Lowercase(string)
Description
Converts any uppercase character found in quoted string to the equivalent lowercase character.
Matrix to BLOB(matrix, type, bytesEach, endian(value))
Description
Makes a BLOB from a matrix by converting the matrix elements to 1-byte, 2-byte, or 4-byte signed or unsigned integers or 4-byte or 8-byte floating point numbers.
Required Arguments
matrix
The matrix.
type
The quoted type of BLOB: int, uint, or float.
bytesEach
The number of bytes in each int, uint, or float. Integers can be 1, 2, or 4 bytes each, and floats can be 4 or 8 bytes each.
endian(value)
Munger(string, start position, find|length, <replacement string>)
Description
Computes new quoted character strings from the quoted string by inserting or deleting characters. It can also produce substrings, calculate indexes, and perform other tasks depending on how you specify its arguments.
Required Arguments
start position
A numeric expression that specifies the starting position to search in the quoted string. If the start position is greater than the position of the first instance of the find argument, the first instance is disregarded. If the start position is greater than the search string’s length, Munger() uses the string’s length as the start position.
find|length
Specifies the string or number of characters to find.
Optional Argument
replacement string
The quoted replacement string. If replacement string is omitted, a substring between start position, and position and length, is returned.
See Also
Munger Function in the Scripting Guide
Num(string)
Description
Converts a quoted character string into a number.
See Also
Regex(source, pattern, (<replacement string>, <format, "GLOBALREPLACE", "IGNORECASE">>)
Description
Searches for the quoted pattern within the quoted source string.
Returns
The matched text as a quoted string or numeric missing if there was no match.
Required Arguments
source
A quoted string.
pattern
A quoted regular expression.
replacement string
The replacement string.
Optional Arguments
format
A backreference to the capturing group. The default is \0, which is the entire matched quoted string. \n returns the nth match.
"IGNORECASE"
The search is case sensitive, unless you specify "IGNORECASE".
"GLOBALREPLACE"
Applies the regular expression to the quoted source string repeatedly until all matches are found.
See Also
Regular Expressions in the Scripting Guide
Remove
See Remove(source, position, <n>).
Remove From
See Remove From(source, position, <n>).
Repeat(source, a)
Repeat(matrix, a, b)
Description
Returns a copy of source concatenated with itself a times. Or returns a matrix composed of a row repeats and b column repeats. The source can be text, a matrix, or a list.
See Also
Repeat Function in the Scripting Guide
Reverse
See Reverse(source).
Reverse Into
See Reverse Into(source).
Right(string, n, <filler>)
Right({list}, n, <filler>)
Description
Returns a truncated or padded version of the original quoted string or list. The result contains the right n characters or list items, padded with any optional filler on the left if the length of string is less than n.
Shift
See Shift(source, <n>).
Shift Into
See Shift Into(source, <n>).
Starts With(string, substring)
Description
Determines whether the quoted substring appears at the start of the quoted string.
Returns
1 if string starts with substring, otherwise 0.
Arguments
string
A quoted string or a reference to one. Can also be a list.
substring
Left(string, Length("substring")) = = "substring"
Substitute
See Substitute(string, "substring", "replacementString", ...).
Substitute Into
See Substitute Into(string, substring, replacementString, ...).
Substr(string, start, length)
Description
Extracts the characters that are the portion of the first argument beginning at the position given by the second argument and ending based on the number of characters specified in the third argument. The first argument can be a character column or value, or an expression evaluating to same. The starting argument and the length argument can be numbers or expressions that evaluate to numbers.
Example
This example extracts the first name:
Substr( "Katie Layman", 1, 5 );
The function starts at position 1, reads through position 5, and ignores the remaining characters, which yields “Katie.”
See Also
Text Score(text column, text-to-number, <weighting>, <{support vectors}>, <text explorer setup>)
Description
Used to create scoring formulas in Text Explorer. Not supported for use with the Stem for Combining option.
Returns
Returns a vector of scores.
Required Arguments
text column
The data table column.
text-to-number
An associative array that maps lowercase words to numbers.
Optional Arguments
weighting
The quoted "Count", "Binary", "Ternary", "LogCount", "LCA", or an array of inverse document frequency weights for TFLogIDF. "Count" is the default value. The default value is "Count".
support vectors
A list of vectors that are used in the text scoring. The number and length of the vectors depends on the weighting argument.
text explorer setup
An expression that contains a block of Text Explorer setup information.
Titlecase(string)
Description
Converts the quoted string to title case; each word in the string has an initial uppercase character and subsequent lowercase characters.
Returns
A quoted string.
Argument
string
A quoted string.
Example
The following function capitalizes the name:
Titlecase( "veronica layman ")
"Veronica Layman"
Trim(string,<"Left"|"Right"|"Both">)
Trim Whitespace(string,<"Left"|"Right"|"Both">)
Description
Removes leading and trailing whitespace from the specified string.
Returns
A quoted string.
Required Argument
string
A quoted string.
Optional Argument
A quoted string that specifies whether whitespace is removed from the left, the right, or both ends of the string. If omitted, whitespace is removed from both ends.
Example
For example, the following command returns "John":
Trim( "  John    ", Both )
"John"
Uppercase(string)
Description
Converts any lowercase character found in the quoted string to the equivalent uppercase character.
Word(n|[first last], string, <delimiter>, <Unmatched(result string)>)
Description
Returns the nth item of the string, where words are substrings separated by any number of any characters in the delimiter argument.
Required Arguments
n
[first last]
string
Optional Arguments
delimiter
The character used as a boundary. If delimiter is absent, an ASCII space is used. If delimiter is the empty quoted string, each character is treated as a separate word.
Examples
This example returns the last name:
Word( 2, "Katie Layman" );
"Layman"
See Also
See Item(n|[first last], string, <delimiter>, <Unmatched(result string)>, <Include Boundary Delimiters(Boolean)>) for examples of how Word() differs from Item().
Words
See Words(string, <delimiter>).
XPath Query(xml, xpath_expression)
Description
Runs an XPath expression on an XML document.
Returns
A list.
Required Arguments
xml
A valid XML document.
xpath_expression
A quoted XPath 1.0 expression.
Example
Suppose that you created a report of test results in JMP and exported important details to an XML document. The test results are enclosed in <result> tags.
The following example stores the XML document in a variable. The XPath Query expression parses the XML to find the text nodes inside the <result> tags. The results are returned in a list.
rpt =
"\[<?xml version="1.0" encoding="utf-8"?>
<JMP><report><title>Production Report</title>
<result>November 21st: Pass</result>
<result>November 22nd: Fail</result>
<note>Tests ran at 3:00 a.m.</note></report>
</JMP> ]\";
results = XPath Query( rpt, "//result/text()" );
{"November 21st: Pass", "November 22nd: Fail"}
