The Variable Clustering red triangle menu contains the following options:
Color Map on Correlations
Shows or hides the Color Map on Correlations plot. See Color Map on Correlations.
Cluster Summary
Shows or hides the Cluster Summary report. See Cluster Summary.
Cluster Members
Shows or hides the Cluster Members report. See Cluster Members.
Cluster Components
Shows or hides the Standardized Components report. See Standardized Components.
Save Cluster Components
Saves columns to the data table as a group called Cluster Components. Each column is named Cluster <i> Components and contains a formula that expresses the cluster component in terms of the uncentered and unscaled variables.
Launch Fit Model
Opens a Model Specification window with the Most Representative Variables for each cluster entered in the Construct Model Effects list. Use this option to construct models based on the Most Representative variables.
Tip: To fit a model using the components, first select the Save Cluster Components option. Then replace the Most Representative variables for each cluster in the Construct Model Effects list with the desired Cluster Components columns.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
