Use the Custom Design platform to construct optimal designs that are custom built for your specific experimental setting. The Custom Design platform enables you to constructs a wide variety of designs, including: Screening, Response Surface, Mixture, Random Block, Split Plot, Split-Split-Plot, and Two-Way Split Plot designs. Use the Custom Design platform to design experiments that include:
• Factors of many different types.
• Constraints on the design space.
• Specific effects are necessary to estimate and effects that are desirable to estimate, if possible, given the number of runs.
• Specify a number of experimental runs that matches your budget.
This chapter contains a detailed example of how to use the Custom Design platform, followed by information about the platform. See also Examples of Custom Designs.
Figure 4.1 Color Map for Absolute Correlations
