Profilers > Custom Profiler > Custom Profiler Platform Options
Publication date: 07/08/2024
The Custom Profiler red triangle menu contains the following options:
Factor Settings
Contains options identical to the Factor Settings submenu in the Prediction Profiler. See Factor Settings.
Log Iterations
Creates a new data table that contains iterations of the optimization algorithm. The data table appears after the Optimize button is clicked.
Alter Linear Constraints
Enables you to add, change, or delete linear constraints. The constraints are used in the Custom Profiler. You can also view and change the bounds for each continuous factor. See Linear Constraints.
Save Linear Constraints
Saves existing linear constraints as a data table script that is named Constraint. See Linear Constraints.
Simulator
Shows or hides the Simulator. See “Simulator”.
