Design of Experiments Guide > Easy DOE > Design with the Easy DOE Platform
Publication date: 07/08/2024
Use the Easy DOE platform to build, enter results of, and analyze an experiment by selecting DOE > Easy DOE. Radio buttons enable you to switch between Guided Mode and Flexible Mode. Guided Mode has additional prompts and guidance to help you build and analyze your design as compared to Flexible Mode. The Easy DOE platform has tabs for each step of the process.
Define
Model
Design
Data Entry
Analyze
Predict
Report
