The Fit Group Orthogonal Supersaturated Design platform red triangle menu contains platform options.
See Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
