The Functional Data Explorer red triangle menu contains the following options:
Summaries
A submenu of the following options for functional summary statistics:
Plot Mean Function
Shows or hides a plot of the functional mean in the Summaries report. On by default.
Plot Standard Deviation Function
Shows or hides a plot of the functional standard deviation in the Summaries report. On by default.
Plot Median Function
Shows or hides a plot of the functional median in the Summaries report.
Models
A submenu of the following model options:
B-Splines
Fits a basis spline (B-Spline) model to the data.
P-Splines
(Not available if there are fewer than three unique input values.) Fits a penalized basis spline (P-Spline) model to the data.
Fourier Basis
(Not available if there are fewer than three unique input values.) Fits a Fourier Basis model to the data.
Wavelets
Fits several wavelet models to the data. This option requires data to be on an evenly spaced grid. If data is not evenly spaced, a grid is automatically created before the wavelet routine.
Model Controls
Shows a submenu that enables you to open the Model Controls panel prior to fitting a model. See Model Controls. This option also enables the Model Selection red triangle menu option to change to the model selection criteria prior to fitting a model.
Direct Models
(Not available if there is only a single function.) Shows a submenu of models that perform functional principal components analysis directly on the data, without fitting a basis function model first.
Note: All of the methods in the Direct Models submenu require that the input data be on an evenly spaced grid. If this is not the case, the first step of each method is to align the input data to be between 0 and 1 and then interpolate the observations to a common grid of input values.
The Functional Data Explorer platforms fits the following direct models:
Direct Functional PCA
Performs a singular value decomposition (SVD) on the stacked matrix of functions to obtain the functional principal component analysis (FPCA) results for the data. See Direct Functional PCA.
Penalized SVD
Performs a penalized singular value decomposition (SVD) on the stacked matrix of functions to obtain the functional principal component analysis (FPCA) results for the data. See Penalized SVD.
Nonnegative SVD
Performs a nonnegative singular value decomposition (SVD) on the stacked matrix of functions to obtain the functional principal component analysis (FPCA) results for the data. See Nonnegative SVD.
Penalized Nonnegative SVD
Performs a penalized nonnegative singular value decomposition (SVD) on the stacked matrix of functions to obtain the functional principal component analysis (FPCA) results for the data. See Penalized Nonnegative SVD.
Multivariate Curve Resolution
Performs a matrix decomposition on the stacked matrix of functions to obtain the functional principal component analysis (FPCA) results for the data. This method decomposes the matrix into a matrix of mixing proportions and a matrix of nonnegative shape functions. See Multivariate Curve Resolution.
Unconstrained MCR
Performs the same type of matrix decomposition as the Multivariate Curve Resolution method, except the shape functions can be negative.
Peak Finding
Identifies and summarizes peaks in the data. You can use automatic peak detection via continuous wavelet transformation (CWT) or manual peak detection. For more information about continuous wavelet transformation, see Du et al (2006).
Save Data
Saves the processed data to a new data table. The processed data are saved in the stacked data format.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
