The JMP Log History contains actions recorded for the entire JMP session. Use the up arrow to add a selected step to the workflow. Alternatively, drag an action to the workflow. Actions are grouped by time. The actions recorded in the JMP Log History are the same actions recorded in the Enhanced Log (View > Log) (Windows) or Window > Log (macOS). Right-click to clear the log history.
