Quality and Process Methods > Manage Limits > Manage Limits Options
Publication date: 07/08/2024
The Manage Limits red triangle menu contains the following options:
Show Limits All
Selects all of the boxes under Show Limits in the Spec Limits table. If Show Limits is selected for a column, the Show as Graph Reference Lines option is selected in the Spec Limits column property. The Show as Graph Reference Lines option displays the specification limits and target that you specify as reference lines in select analysis plots.
Note: If all boxes under Show Limits are selected, the Show Limits All option deselects all of the boxes under Show Limits.
Round Decimals
Sets the number of decimal places to round the limits or metadata values to.
Color Out of Spec Values
Colors any values in the data table that are outside the specification limits for the columns. Values that are below the lower specification limit are colored red and values that are above the upper specification limit are colored blue.
See Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
