The Reliability Forecast red triangle menu contains the following options:
Save Data in Time to Event Format
Saves Nevada or Dates formatted data in a Time to Event formatted table.
Show Legend
Shows or hides a legend for the Observed Data report. Unavailable for Time to Event data.
Show Graph Filter
Shows or hides the Graph Filter so that you can select which production periods to show in the Observed Data graphs. Bars fade for deselected periods. Deselect the periods to show the graph in its original state. Unavailable for Time to Event data.
See Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
Save By-Group Script
