Basic Analysis > Text Explorer > Text Explorer Platform Options > Report Options in Text Explorer
Publication date: 07/08/2024
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
