This appendix discusses the different types of response models, their factors, their design coding, and parameterization. It also includes many other details of methods described in the main text.
The JMP system fits linear models to three different types of response models that are labeled continuous, ordinal, and nominal. Many details about the factor side are the same for the different response models, but JMP supports graphics and marginal profiles only for continuous responses—not for ordinal and nominal.
Different computer programs use different design-matrix codings, and thus parameterizations, to fit effects and construct hypothesis tests. JMP uses a different coding than the GLM procedure in SAS, although in most cases JMP and SAS GLM procedure produce the same results. The following sections describe the details of JMP coding and highlight those cases when it differs from that of the SAS GLM procedure.
