Publication date: 07/08/2024
The Manova Fit Options
The Manova Fit red triangle menu contains the following options:
Save Discrim
(Available only when one categorical effect is present in the model.) Saves new columns to the data table. The new columns contain the Mahalanobis distances, the probability for membership in each level of the effect, and the predicted level with the highest probability. See Discriminant Analysis in Multivariate Response Models.
Save Predicted
Saves new columns to the data table. The new columns contain the predicted values for each response in the model.
Save Residuals
Saves new columns to the data table. The new columns contain residuals for each response in the model.
Model Dialog
Shows the completed Fit Model launch window for the current analysis.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
