DRAFT help
Publication date: 09/20/2024
Add Fill Patterns
In a JMP graph, Fill Pattern() sets the pattern for filled areas.
Matrix Example
Specify a mask (a matrix of values between 0 and 1) or an image. Each value in the matrix creates a pixel.
win = New Window( "Example",
	Graph Box(
		Fill Pattern(
			[1 0.5 0 0, 0.5 0 0 1, 0 0 1 0.5, 0 1 0.5 0]
		Polygon( [10 30 90], [88 22 44] );
Named Pattern Example
Specify a name in quotation marks that corresponds to a pattern shown in Table 12.3.
win = New Window( "Named Pattern Example",
	Graph Box(
		Fill Pattern( "vertical light" );
Graphic Example
Specify an image in quotation marks. If the image is not installed on the viewer’s computer, question marks appear in the shape.
win = New Window( "Graphic Example",
	Graph Box(
		Fill Pattern( Open( "$SAMPLE_IMAGES/pi.gif", "gif" ) );
Table 12.3 Fill Patterns
Pattern Name
Pattern
left slant light
right slant light
vertical light
horizontal light
grid light
hatch light
h wave light
v wave light
hollow circle
left slant medium
right slant medium
vertical medium
horizontal medium
grid medium
hatch medium
h wave medium
v wave medium
filled circle
left slant heavy
right slant heavy
vertical heavy
horizontal heavy
grid heavy
hatch heavy
h wave heavy
v wave heavy
diamond
left slant heavy b
right slant heavy b
random
square
square offset
wide
tall
checkerboard
grid dots
triangle up
triangle down
triangle left
triangle right
weave light
weave heavy
honeycomb
