DRAFT help
Build a Taguchi Design by selecting DOE > Classical > Taguchi Arrays. The Taguchi design updates as you work through the design steps
• Responses
• Factors
• Choose Taguchi Inner and Outer Array Designs
• Display Coded Design
• Make the Design Table
