DRAFT help
Publication date: 09/20/2024
Responses
Use the Response section to specify a response for a Taguchi design.
Figure 15.8 Response
Response
The Response section contains the following columns:
Response Name
The name of the response (the default is Y). To change this name, double-click it and enter a different name.
Goal, Lower Limit, Upper Limit
The Goal determines the form of the signal-to-noise function (Table 15.1). Select one of the following Goals: Larger Is Better, Nominal is Best, Smaller is Better, or None. When you create your design, JMP saves a formula for the SN Ratio to the data table that reflects your selected goal. To change a goal, click it and enter a different goal. Use the Lower and Upper Limits if you have limits on your response.
Importance
When you have several responses, the Importance values that you specify are used to compute an overall desirability function. These values are treated as weights for the responses. In a Taguchi Design there is only one response, the Importance is set to 1 by default. No value is needed for the Importance.
