DRAFT help
Using JMP > JMP Reports > Change the Appearance of JMP Graphs
Publication date: 09/20/2024
There are many ways that you can format your JMP report to meet your needs. The sections that follow detail how to make changes to the graphical portions of your output reports.
Tip: If you have a touchscreen, you can pan and zoom most graphs and axes in JMP. Graphs and axes change scale and zoom out if pinched, and zoom in if stretched.
Resize Graphs
Zoom In on Graphs
Change Line Widths in Graphs
Change the Background Color in Graphs
Change the Color of Histogram Bars
Display Coordinates and Temporary Reference Lines in Graphs
Scroll and Scale Axes in Graphs
Customize Axes and Axis Labels in Graphs
Change the Order of Values in Reports
Change the Pattern and Format of Selected Objects in Graphs
Add a Graph to a Data Table
Customize Markers, Lines, Text, and More in Graphs
