You can measure points and distances in JMP graphs, or easily find the exact value, or coordinates, of points and distances on plots and graphs.
To find exact values or coordinates, click the crosshairs tool and click and hold anywhere on a graph. The coordinate values appear where the crosshairs intersect the vertical and horizontal axis as you drag the crosshairs within a plot.
Figure 9.26 Using the Crosshairs Tool
On a fitted line or curve, the crosshairs identify the response value for any predicted value. On a ternary plot, this tool displays triangular crosshair lines.
To measure the approximate distance between two values or coordinates in a graph, use the ruler tool. Click the ruler tool then click and hold anywhere on the graph. Next, drag the cursor to the second point to which you want to measure the distance. The distance values appear at the end of the ruler in a display box. The box displays three values: the direct distance between the two points as well as the change in x as dx and change in y as dy.
Figure 9.27 Using the Ruler tool
On graphs whose values are the same data type, the ruler is displayed as a straight line between the point where you first clicked and the current location of the cursor, as seen in the example. For graphs whose values are different data types, such as graphs featuring nominal variables and continuous variables, the ruler is displayed instead as a horizontal line and a vertical line as seen in Figure 9.28.
The ruler tool displays the distance between date variables in the format day:hour:minute:second.
In the example below, the X axis represents a date variable. Using the ruler tool to measure between one point of the low group to another coordinate in the higher group shows that the difference between the two chosen coordinates is 3,685 days, 9 hours, 45 minutes, and 3 seconds.
Figure 9.28 Approximating the Difference Between Two Date Variables
Figure 9.29 Measuring the Distance Between Nominal Variables
