DRAFT help
Publication date: 09/20/2024
Change the Orientation of a Formula
By default, JMP determines the size of a formula and displays it in the Formula Editor in the best orientation (horizontally or vertically). However, if you create a long formula, you might want to display it in a different layout.
To change a formula’s orientation, follow these steps:
1. Build a formula.
2. Highlight an argument or formula.
3. Right-click what you have highlighted.
4. Select Orientation.
5. Select from the Orientation options: Best, Horizontal, or Vertical.
