DRAFT help
Using JMP > Create Formulas in JMP
Publication date: 09/20/2024
Formula Editor
Use the JMP Formula Editor to create a column whose values are computed by a formula and store that formula as part of a column’s information. Formulas can be simple assignments of numeric, character, or row state constants, or they can contain complex evaluations based on conditional clauses. The Formula Editor window operates like a calculator with buttons, displays, and a list of functions.
For more information about the functions that are available in the Formula Editor, see “Reference for JMP Functions in Formulas”.
Figure 7.1 The Formula Editor
The Formula Editor
Contents
Overview of Formulas in JMP
Refer to Data Table Values in Formulas
Use Local Variables in Formulas
Incorporate Parameters in Formulas
Insert Constants in Formulas
Add Operators to JMP Formulas
Keypad Reference for the Formula Editor
Use Functions in Formulas
Find Frequently Used Functions in the Formula Editor
Copy and Replicate Formulas
Order Expressions in Formulas
Build a Formula in Order of Precedence
JMP Formula Editor Options
Calculate Derivatives of JMP Functions
Simplify Complex Formulas
Evaluate Formulas
Ignore Errors in Formulas
View Formulas in JSL
Edit Formulas
Correct Mistakes in Formulas
Select Expressions in Formulas
Delete Functions from Formulas
Cut, Copy, and Paste Formulas
Click and Drag Formulas
Customize Formulas in the JMP Formula Editor
Hide and Show Outlines in Formulas
Change the Font Size in Formulas
Specify the Matrix Size in Formulas
Change the Orientation of a Formula
Open and Close Arguments in Formulas
Examples of Building Formulas in the JMP Formula Editor
Use Basic Features in the JMP Formula Editor
Use the Munger Function in Formulas
Use the Match Conditional Function in Formulas
Use the Delete Expression Button in Formulas
Keyboard Shortcuts for the JMP Formula Editor
Glossary of Terms for the JMP Formula Editor
