DRAFT help
Using JMP > Create Formulas in JMP > Edit Formulas > Correct Mistakes in Formulas
Publication date: 09/20/2024
If you make a mistake while entering a formula in the JMP Formula Editor, press Ctrl+Z. This reverses the effect of the last (undo-able) command.
Other commands to help modify formulas include the following:
Click the delete button (Image shown here) on the Formula Editor keypad to remove the selected expression.
Use the cut, copy, and paste keyboard shortcut commands or right-click a highlighted part of the formula and select Cut, Copy, or Paste from the menu.
Drag portions of the formula to rearrange them.
