DRAFT help
Quality and Process Methods > CUSUM Control Charts
Publication date: 09/20/2024
Create Tabular CUSUM Control Charts with Decision Limits
Cumulative Sum (CUSUM) control charts enable you to detect small shifts in a process. They are useful in detecting shifts that occur over time, such as a gradual drift, and that are not necessarily accompanied by a sudden shift. The CUSUM Control Chart platform creates a CUSUM chart with decision limits, similar to a Shewhart chart. This chart is also called a tabular CUSUM chart. To create a V-mask cumulative sum control chart, see “V-Mask CUSUM Control Charts”.
The CUSUM Control Chart platform also provides information about average run length (ARL). The average run length is the average number of samples or observations that can be expected to occur before an out-of-control signal occurs. You can use the average run length to assess the performance of a CUSUM chart, given specific parameters and assuming constant variance.
Figure 10.1 CUSUM Control Chart
CUSUM Control Chart
Contents
Overview of the CUSUM Control Chart Platform
Example of a CUSUM Control Chart
Launch the CUSUM Control Chart Platform
The CUSUM Control Chart Platform Report
Control Panel for CUSUM Control Chart
CUSUM Chart Report
CUSUM Control Chart Platform Options
Average Run Length (ARL) Report
Additional Examples of CUSUM Control Charts
Example of the Data Units Option in a CUSUM Control Chart
Example of a CUSUM Chart with Subgroups
Statistical Details for the CUSUM Control Chart Platform
Statistical Details for CUSUM Control Chart Construction
Statistical Details for Shift Detection
Statistical Details for Average Run Length
