DRAFT help
Using JMP > Create Formulas in JMP > Edit Formulas > Cut, Copy, and Paste Formulas
Publication date: 09/20/2024
You can cut or copy any expression or an entire formula and paste it into another formula in the JMP Formula Editor. Use the cut, copy, and paste shortcut commands or right-click a highlighted part of the formula and select Cut, Copy, or Paste from the menu. The following aspects apply when you cut, copy, and paste a formula:
When you paste it into another formula display, the formula appears in formatted form.
The formula is saved on the clipboard as a JSL statement. Thus, if you copy it into other applications, it appears as a JMP Scripting Language (JSL) statement.
Note: Press Shift and click the red triangle to reveal a command called Copy As SAS Formula.
