DRAFT help
Using JMP > Import Your Data > Import PDF Files > Data Table Preview Options
Publication date: 09/20/2024
This section describes options that are on the data table preview pane.
Auto-detect tables
If you previously divided or combined tables, this option reverts the changes you made so that the tables are auto-detected again.
Ignore all tables
Removes the tables from the PDF file. The data is not imported.
Minimum column count
Avoids importing tables that have fewer columns than specified.
Minimum row count
Avoids importing tables that have fewer rows than specified.
Concatenate all tables into one
Combines rows from two or more data tables into one data table.
Individual tables
Imports the data into multiple tables.
Concatenate tables with matching column names
Combines rows from two or more data tables that have matching column names into one data table.
