DRAFT help
Using JMP > Import Your Data > Import PDF Files
Publication date: 09/20/2024
Import PDF Files
The PDF Import Wizard enables you to preview a PDF file, adjust the import settings, and view the results in the data table preview before you import the data. JMP attempts to auto-detect the data structure in the PDF file, or you can customize the structure.
Note: A PDF file consists of tables that contain data. In the PDF preview, the tables are outlined and selected on each page.
Concatenate Tables into One Data Table
Concatenate Tables by Column Headers
Import Tables that JMP Does Not Auto-Detect
PDF Preview Red Triangle Options
Data Table Preview Options
PDF Preview Right-Click Options
