DRAFT help
Scripting Guide > Python > JSL-to-Python Interfaces > Equivalent Data Types for Python Get()
Publication date: 09/20/2024
Table 15.2 shows which JMP data types can be exchanged with Python using the Python Get() function. Getting lists from Python recursively examines each element of the list and gets each base Python data type. Nested lists are supported.
Table 15.2 Equivalent Python and JMP Data Types for Python Get()
Python Data Type
JMP Data Type
numpy.ndarray
Numeric Matrix
jmp.DataTable.Column
Column
jmp.DataTable
Data Table
Pandas.DataFrame
Data Table
Dictionary
Associative Array
Integer
Integer
List
List of converted Python data types
Matrix
Numeric Matrix
Set
List
Unicode String
String
Python Get() Example
Names Default To Here( 1 );
x1 = {1, 2, 3};
Python Send( x1 );
x2 = Python Get( x1 );
Show( x1, x2 );
