This example does the following:
• Runs an analysis on a data table, producing a report
• Applies red triangle menu options and format settings to create a customized report
• Saves the applied settings as a new Platform Preset
• Applies that Platform Preset to another report
1. Select Help > Sample Data Folder and open Cereal.jmp.
2. Select Analyze > Multivariate Methods > Multivariate.
3. Select the columns from Calories through Potassium and click Y, Columns, and then click OK.
Figure 10.3 The Initial Multivariate Report Window
4. On the Multivariate menu bar, select the Red Triangle, then Color Maps > Color Map on Spearman’s ρ.
5. From the Red Triangle menu on the Multivariate menu bar, deselect Correlations Multivariate and Scatterplot Matrix.
6. Double-click the X Axis to open X Axis Settings, then click the Font button.
7. Set the Size to 14, and click OK.
8. In the X Axis Settings, click OK to apply your changes.
Figure 10.4 The Customized Report Window
9. Click the Platform Presets button in the Multivariate menu bar, then click Save Preset As.
10. In the Name field, enter Nonparametric Color Map, then click OK.
You can now apply the saved preset to another report.
1. Select Help > Sample Data Folder and open Candy Bars.jmp.
3. Select the columns from Serving/pkg through Protein g and click Y, Columns, and then click OK.
4. In the Multivariate menu bar, click the Platform Presets button , then select My Presets > Nonparametric Color Map.
Figure 10.5 The Report Window with the New Platform Preset Applied
