DRAFT help
Publication date: 09/20/2024
Example of an Equivalence Test
Use the Oneway platform to investigate whether an alternative drug is not inferior to morphine for a procedure in dogs. Compare the difference in the first two time points.
1. Select Help > Sample Data Folder and open Dogs.jmp.
3. Select diff and click Y, Response.
4. Select drug and click X, Factor.
5. Click OK.
6. Click the Oneway Analysis red triangle menu and select Equivalence Tests > Means.
Figure 6.26 Equivalence or Noninferiority Tests Window
7. Select Noninferiority (One-Sided).
8. Leave the variance assumption set to Pooled Variance.
9. Set the Difference to 1. This is the noninferiority margin.
10. Click OK.
Figure 6.27 Example of a Test for Noninferiority
The observed difference in the response for the two drugs was -0.639 units. The lower bound on the confidence interval of -1.93 falls below the lower noninferiority limit of -1.0. You do not conclude that the alternative drug is not inferior to the standard drug.
