DRAFT help
Welcome to JMP > Learn about JMP > JMP Help Menu
Publication date: 09/20/2024
JMP Help Menu
Starting at JMP 18, the JMP help menu has been updated.
Menu Item
Description
Search JMP
Enables you to search JMP for statistical tests and other capabilities. For more information, see Search JMP.
JMP Online Help
Enables you to open the latest version of the Help in a web browser.
Help Tool
Enables you to click on any part of a data table or report window to get help.
Quick Start
Formerly referred to as Tip of the Day, the Quick Start provides you with tips to help you quickly learn the basics of JMP. For more information, see Get Started with JMP.
Documentation PDFs
When installed, it provides local access to the JMP documentation PDF files. For more information, see Documentation PDF Add-in.
Note: This menu option appears only if the documentation add-in is downloaded and installed.
JMP Capabilities
Opens a web browser that lists the tools and features that are available in JMP. It also provides links to the online Help, where more information is available.
Learn JMP
Opens a web browser that takes you to JMP learning materials. You can learn JMP through short videos and other resources.
JMP User Community
Opens a web browser where you can connect with other JMP users to learn more, solve problems, and share ideas for improving JMP. For more information, see JMP User Community.
New in JMP
Opens a web browser where you can learn about the new features in the latest release of JMP.
Sample Data Folder
Enables you to access sample data to learn about JMP analyses. Open a sample data file and run a script to see a sample analysis. For more information, see Sample Data Tables.
Sample Index
Enables you to find sample data tables based on analysis type or industry, teaching resources, and links to additional sample material. For more information, see Sample Data Tables.
Scripting Index
Enables you to search for JMP scripting commands and learn how to use them. For more information, see Learn about JSL.
My JMP
Opens https://my.jmp.com on the web.
About JMP
Displays your JMP version and enables you to check for software updates. This option is available only on Windows.
