The JMP Online Help enables you to search for information about JMP features, statistical methods, and the JMP Scripting Language (JSL). You can open JMP Online Help several ways:
• On Windows, select Help > JMP Online Help.
• On Apple macOS, select Help > JMP Help.
• On Windows, press the F1 key.
• To get help on a specific part of a data table or report window, select Help > Help Tool. Then, click anywhere in a data table or report window. To dismiss the Help tool, press the Esc key.
• Within a JMP window, click the Help button.
Note: The JMP Help is available for users with internet connections. Users without an internet connection can install the documentation add-in. See Documentation PDF Add-in for more information.
