DRAFT help
Quality and Process Methods > Legacy Control Charts
Publication date: 09/20/2024
Create Variable and Attribute Control Charts
The legacy control chart platforms in JMP provide a variety of control charts, as well as runs charts, V-Mask CUSUM charts, and weighted moving average charts. To support process improvement initiatives, most of the control chart options display separate control charts for different phases of a project on the same chart.
A control chart is a graphical and analytic tool for monitoring process variation. The natural variation in a process can be quantified using a set of control limits. Control limits help distinguish common-cause variation from special-cause variation. Typically, action is taken to identify and eliminate special-cause variation. It is also important to quantify the common-cause variation in a process, as this determines the capability of a process.
Figure 14.1 Control Chart Example
Contents
Overview of Legacy Control Charts
Legacy Control Charts for Variables
Legacy Control Charts for Attributes
Example of a Legacy Control Chart
Launch a Legacy Control Chart Platform
Process Information
Limits Specifications
Specified Statistics
Legacy Control Chart Reports
V-Mask CUSUM Chart Reports
Interpret a Two-Sided V-Mask CUSUM Chart
Interpret a Legacy One-Sided CUSUM Chart
Legacy Control Chart Platform Options
Window Options for Legacy Control Charts
Chart Options for Legacy Control Charts
Chart Options for V-Mask CUSUM Control Charts
Saving and Retrieving Limits
Excluded, Hidden, and Deleted Samples
Additional Examples of Legacy Control Charts
Example of Presummarized Charts
Example of a V-Mask CUSUM Chart
Example of a One-Sided CUSUM Chart
Example of a UWMA Chart
Statistical Details for Legacy Control Charts
Statistical Details for Median Moving Range Charts
Statistical Details for Capability Analysis
Statistical Details for V-Mask CUSUM Control Charts
Statistical Details for Weighted Moving Average Charts
