DRAFT help
Quality and Process Methods > Legacy Control Charts > Excluded, Hidden, and Deleted Samples
Publication date: 09/20/2024
The following table summarizes the effects of various conditions on samples and subgroups in legacy control charts:
Table 14.2 Excluded, Hidden, and Deleted Samples
All rows of the sample are excluded before creating the chart.
Sample is not included in the calculation of the limits, but it appears on the graph.
Sample is excluded after creating the chart.
Sample is included in the calculation of the limits, and it appears in the graph. Nothing changes on the output by excluding a sample with the graph open.
Sample is hidden before creating the chart.
Sample is included in the calculation of the limits, but does not appear on the graph.
Sample is hidden after creating the chart.
Sample is included in the calculation of the limits, but does not appear on the graph. The sample marker disappears from the graph, the sample label still appears on the axis, but limits remain the same.
All rows of the sample are both excluded and hidden before creating the chart.
Sample is not included in the calculation of the limits, and it does not appear on the graph.
All rows of the sample are both excluded and hidden after creating the chart.
Data set is subsetted with Sample deleted before creating chart.
Sample is not included in the calculation of the limits, the axis does not include a value for the sample, and the sample marker does not appear on the graph.
Data set is subsetted with Sample deleted after creating chart.
Sample is not included in the calculation of the limits, and does not appear on the graph. The sample marker disappears from the graph, the sample label is removed from the axis, the graph shifts, and the limits change.
Some additional notes:
Hide and Exclude operate only on the row state of the first observation in the sample. For example, if the second observation in the sample is hidden, but the first observation is not hidden, the sample still appears on the chart.
Note: Excluded rows in Presummarize charts are excluded from calculations, regardless of which position they are within a sample.
An exception to the exclude/hide rule: Both hidden and excluded rows are included in the count of points for Tests for Special Causes. An excluded row can be labeled with a special cause flag. A hidden point cannot be labeled. If the flag for a Tests for Special Causes is on a hidden point, it will not appear in the chart.
Because of the specific rules in place (Table 14.2), the control charts do not support the Automatic Recalc script.
