DRAFT help
Consumer Research > MaxDiff > MaxDiff Model Report > Likelihood Ratio Tests
Publication date: 09/20/2024
In the MaxDiff Model report, the Likelihood Ratio Tests section i provides the following metrics:
Source
Lists the effects in the model.
L-R ChiSquare
The value of the likelihood ratio ChiSquare statistic for a test of the corresponding effect.
DF
The degrees of freedom for the ChiSquare test.
Prob>ChiSq
The p-value for the ChiSquare test.
Bar Chart
Shows a bar chart of the L-R ChiSquare values.
