DRAFT help
Publication date: 09/20/2024
MaxDiff
Fit Models for MaxDiff Experiments
Use MaxDiff (maximum difference scaling) as an alternative to standard preference scales to determine the relative importance of items being rated. MaxDiff forces respondents to report their most and least preferred options. This often results in rankings that are more definitive than rankings obtained using standard preference scales.
The MaxDiff platform enables you to do the following:
Use information about respondent (subject) traits as well as product attributes.
Integrate data from one, two, or three sources.
Obtain subject-level scores for segmenting or clustering your data.
Image shown hereEstimate subject-specific coefficients using a Bayesian approach.
Use bias-corrected maximum likelihood estimators (Firth 1993).
Figure 5.1 MaxDiff All Comparisons Report
Contents
Overview of the MaxDiff Platform
Examples of the MaxDiff Platform
Example of a One Table Format
Example of a Multiple Table Format
Launch the MaxDiff Platform
Launch Window for One Table, Stacked
Launch Window for Multiple Tables, Cross-Referenced
MaxDiff Model Report
MaxDiff Effect Summary
MaxDiff Results
MaxDiff Parameter Estimates
Bayesian Parameter Estimates
Likelihood Ratio Tests
MaxDiff Platform Options
Comparisons Report
Save Bayes Chain
