DRAFT help
Basic Analysis > Logistic Analysis > Logistic Analysis Reports
Publication date: 09/20/2024
The Logistic platform enables you to create visualizations and fit models to explore the relationship between a continuous X variable and a categorical Y variable. This section contains information about the reports that are generated for specific analysis options.
ROC Curves
Inverse Prediction
