DRAFT help
Basic Analysis > Logistic Analysis
Publication date: 09/20/2024
Logistic Analysis
Examine Relationships between a Categorical Y and a Continuous X Variable
Use the Logistic platform to fit a logistic regression model to a categorical Y variable with a continuous X variable. You can view ROC curves, lift curves, and odds ratio estimates. The fitted model provides estimated probabilities for each value of the X variable. You can also perform inverse prediction, which enables you to predict the X value for a specific probability value of the Y variable.
The Logistic platform is the nominal or ordinal by continuous personality of the Fit Y by X platform. There is a distinction between nominal and ordinal responses in this platform:
Nominal logistic regression models estimate a set of curves that partition the probability among the levels of a nominal response variable. An example of a nominal logistic regression model is shown on the right side of Figure 8.1.
Ordinal logistic regression models estimate the probability of being less than or equal to a target level of an ordinal response variable. The model estimates a single logistic curve that gets shifted horizontally to produce probabilities for the ordered categories. This model is less complex and is recommended for ordered responses. An example of an ordinal logistic regression model is shown on the left side of Figure 8.1.
Figure 8.1 Examples of Ordinal and Nominal Logistic Regression
Contents
Overview of the Logistic Platform
Example of Nominal Logistic Regression
Launch the Logistic Platform
Data Format
The Logistic Report
Logistic Plot
Iterations Report
Whole Model Test Report
Fit Details Report
Parameter Estimates Report
Logistic Platform Options
Logistic Analysis Reports
ROC Curves
Inverse Prediction
Additional Examples of Logistic Regression
Example of Ordinal Logistic Regression
Example of a Logistic Plot
Example of ROC Curves
Example of Inverse Prediction
Statistical Details for the Logistic Platform
