DRAFT help
Publication date: 09/20/2024
Make the DOE Results Table
The final step in the DOE workflow is to make a data table to collect your DOE results. Most platforms provide an Output Options node or panel. Depending on the platform and the design, you can use the Output Options panel to specify additional design structure. For example, you can specify the number of runs, center points, replicates, or the order in which you want the design runs to appear in the generated data table.
The Output Options panel shown in Figure 3.23 is for the experiment in the Wine Data.jmp sample data table, located in the Design Experiment folder. In this example, you can choose various Run Order options and construct the design data table. Or, you can choose to go Back and restructure your design.
Figure 3.23 Output Options Panel for Wine Experiment
