DRAFT help
Fitting Linear Models > Multivariate Response Models
Publication date: 09/20/2024
Fit Relationships Using MANOVA
The Manova personality of the Fit Model platform enables you to fit multivariate models. Multivariate models fit several responses (Y variables) to a set of effects. The functions across the Y variables can be tested with appropriate response designs.
In addition to creating standard MANOVA (Multivariate Analysis of Variance) models, you can use the following techniques:
Repeated measures analysis when repeated measurements are taken on each subject and you want to analyze effects both between subjects and within subjects across the measurements. This multivariate approach is especially important when the correlation structure across the measurements is arbitrary.
Canonical correlation to find the linear combination of the X and Y variables that has the highest correlation.
Discriminant analysis to find distance formulas between points and the multivariate means of various groups so that points can be classified into the groups that they are most likely to be in. A more complete implementation of discriminant analysis is in the Discriminant platform.
The multivariate fit begins with a rudimentary preliminary analysis that shows parameter estimates and least squares means. You can then specify a response design across the Y variables and multivariate tests are performed.
Contents
Example of a Multivariate Response Model
Launch the Manova Personality
The Manova Fit Report
The Manova Fit Options
Response Specification Panel
Multivariate Response Reports
Multivariate Tests in Multivariate Response Models
The Extended Multivariate Report
Comparison of Multivariate Tests
Univariate Tests and the Test for Sphericity
Multivariate Response Models with Repeated Measures
Discriminant Analysis in Multivariate Response Models
Additional Examples of the Manova Personality
Example of a Compound Multivariate Model
Example of a Repeated Measures Multivariate Model
Example of the Save Discrim Option
Example of Univariate and Sphericity Test
Example of Test Details
Example of Canonical Correlation Analysis
Statistical Details for the Manova Personality
Statistical Details for Multivariate Tests
Statistical Details for Approximate F-Tests
Statistical Details for Canonical Calculations
