DRAFT help
Publication date: 09/20/2024
Statistical Details for Approximate F-Tests
To compute F-values and degrees of freedom, let p be the rank of Equation shown here. Let q be the rank of Equation shown here, where the L matrix identifies elements of Equation shown here associated with the effect being tested. Let v be the error degrees of freedom and s be the minimum of p and q. Also let Equation shown here and Equation shown here.
Table 10.2, gives the computation of each approximate F from the corresponding test statistic.
Table 10.2 Approximate F-statistics
Test
Approximate F
Numerator DF
Denominator DF
Wilks’ Lambda
Equation shown here
Equation shown here
Equation shown here
Pillai’s Trace
Equation shown here
Equation shown here
Equation shown here
Hotelling-Lawley Trace
Equation shown here
Equation shown here
Equation shown here
Roy’s Max Root
Equation shown here
Equation shown here
Equation shown here
