DRAFT help
JSL Syntax Reference > JSL Messages > Display Box Messages > Number Col Edit Box Messages
Publication date: 09/20/2024
Number Col Edit Box<<Set Format(<width>, <decimal places>, <"Use Thousands Separator">|<other options>)
Description
Sets the column format.
Arguments
A number of other formats can be set on number col edit boxes.
See Also
Number Col Box<<Set Format(<width>|<width, decimal places>, <"Use Thousands Separator">)
“Numeric Formats” in Using JMP describes the arguments.
Number Col Edit Box<<Remove Element(x position, y position, i)
Removes an element from the column at the specified position.
