To open a data set, select File > Open and select the file type. Some file types have additional features and options that appear in the Open Data File window (Table 2.1).
Tips:
• (Windows only) To open the same file type every time, select the Select this filter the next time this window is invoked check box.
• Open a file by dragging it onto the JMP Home Window.
• To change which directory the File > Open command looks in, see “Preferences for File Locations”.
• For more information about opening files, see “Import Your Data”.
File Type |
Additional Features and Options |
JMP Data Tables |
Table notes, the number of columns (Cols), and the number of rows appear. Use the Select Columns option to select which columns are imported into the data table. On Windows, click the arrow next to Open and then use the Select Columns option to specify which columns are imported into the data table. On Apple macOS, you can select which columns to import after you click Open. |
Excel Files |
• Import the file in the Excel Import Wizard by default to customize the layout and preview the data before you import it. • Click the arrow next to Open and then select one of the options. Convert the first spreadsheet row into column headings. |
Text Files |
• To automatically determine data arrangement, select one of the following options: – Data (Using Preferences) – Data (Best Guess) – Text in the Script Editor • To manually specify data arrangement, select the Data (Using Preview) option. See “Options in the JMP Text Import Wizard”. |
SAS Data Sets |
• Use SAS variables for column names • (Windows only) Enter a password when you open a password-protected data set. • (SAS Transport files only) Select columns before opening |
SPSS Data Files |
Use SPSS variable or label names for column names. |
XML Data Files |
See Text Files for more information about the options. |
JSON Data Files |
All Files |
• To automatically determine data arrangement, select one of the following options: – Open as data using preferences – Open as data using a best guess – Open as plain text into a script window • To manually specify data arrangement, select the Data (Using Preview) option. • (Windows only) To open text files using your computer’s default text editor, select Use default program to open. |
